Author Topic: Soldering supplies in Spain  (Read 1528 times)
Offline GoodCrossingTopic starter
« on: July 11, 2018, 07:34:05 pm »
Hello!
I am starting out and I'd like to get proper soldering equipment, and I've been looking to buy Multicore solder but can't find it anywhere in Spain - not even Henkel's website says anything about it. Where do you get your solder?
Offline luiHS
Re: Soldering supplies in Spain
« Reply #2 on: July 11, 2018, 07:56:03 pm »
Thank you!  ;D
Offline exe
  • self-educated hobbyist
« Reply #3 on: July 13, 2018, 09:54:02 am »
I bought mine from tme.eu. I think it was branded differently (but not sure). I think it was Stannol. Are Stannol and Multicore the same thing?
But even if not, I wouldn't care too much about it. The bottleneck is not flux or solder, but the engineer :). Just don't buy total crap from China, and you'll be fine, imho.
Offline Wirehead
    • Wirehead.be
« Reply #4 on: July 13, 2018, 10:06:44 am »
Yeah in Europe Stannol is well available. HS10 is my go-to leaded solder.  :-+ - Ersa for equipment can be bought in many places. The T12 clones aren't bad either with real tips.
"to remain static is to lose ground"
The following users thanked this post: exe
« Reply #5 on: July 13, 2018, 05:17:06 pm »
Spain, huh, JBC?
I'm currently using a no-name, iron that plugs directly into the mains, but I'm looking around for a good station.
[...] Are Stannol and Multicore the same thing?
It looks like they are both property of Henkel, so I'm wondering that too...
Offline exe
« Reply #6 on: July 13, 2018, 07:08:47 pm »
Just looked at my spool, I also use HS10. And Chinese t12. Tips not original, but I'd qualify them as very good (so far).
« Reply #7 on: July 14, 2018, 12:27:31 am »
Spain, huh, JBC?
Just kidding, but don't go for a JBC. The price-performance return is low.
An entry level Hakko, Weller or a used Metcal should serve you well and when you are in the game, you should know whether you need a $1000+ JBC station.
Yep, I'm probably going for a Hakko 888D as I live near the official distributor so I can get one for about 100€.
