Clean up all the pads absolutely flat, apply solder paste sparingly, place the IC on and tack the corners, warm the entire IC and surrounding pcb evenly with hot air then go to the underside and do the same, back and forwards if required, bring the hot air up to reflow temp, give the underside one last blast at reflow temp and then do a full reflow from the top.
If you feel it may easily move when getting to the underside of the pcb use kapton tap to secure it from the top first. Don't be too concerned about perfect reflow of the pins at first as they can be touched up if required later. One disadvantage of not reflowing it all at once though is you will not beable to see the IC align itself automatically due to the meniscus effect of the molten solder. If you use kapton tape obviously you need the area to cool before removing it.
