I recently swapped my old Rokonet RP-808 alarm panel with a newer one because the old one didn't support ContactID.
Anyway, I was examining the old alarm panel PCB and have some questions.
Here is a pic of the back side at the bottom, where the zones connect
1) The big copper traces are the ground plane. Why does it have this checkered pattern?
2) Why the wiggly trace between positive and negative in the red circle?
3) What's that in the blue circle? I measured it with a MM and looks like a resistor?
4) What is the device in the yellow circle? I tested it and it looks like a diode, but it has 1K resistance when forward biased.
Also what is this mystery device? I couldn't find a datasheet.
The engraved circle at the center says "MEXICO AA"
