It's been a very long time since I've done trig, so I too would like to avoid it, if possible.
Before I dive further into this project it gives me some confidence to know that you were successful with it.
So, could you tell me what separation distance you used between the artwork & the led boards & what you consider to be the max size board you could expose with this arrangement?
I have built it on a eurocard-sized piece of stripboard, pretty much the same as the guy in the instructable.
Re max size of the board - that depends a lot on the distance of the LED array from the board and exposure time. I haven't played too much with it, but I wouldn't go beyond something like eurocard with it - the lighting wouldn't be uniform towards the edges anymore. Small boards are fine.
Were you able to establish exposure times for different size boards?
Did you make any significant changes to the author's design?
For me it took about a minute to expose my board, at cca 25cm distance. However, that may no work the same for you - different LEDs and I am using the dry film negative resist (the foil that you laminate on the board). You will need to experiment.
I must say I don't like the author's power rails setup. Too easy to create short circuits. I used individual raised pins from a male header strip with heat sink inter stages.
Yes, the shorts were a problem, all it takes is a little solder bridge or molten insulation on the wires. However, the wiring can be done in various ways, it is not all that critical.
Did you persist with the author's recommended & finicky smd type installation of the resistors, or did you install them instead on the led side of the board? I found that if you don’t follow the authors smd style install, but install the resistors through hole with short raised leads they tend to short curcuit against adjacent solder joints with handling.
Thanks for any feedback.
I have put them "smd-style" as he did. I didn't have any shorts with them - just make sure you align the leads along the stripboard track before soldering & cutting, don't leave them "hanging over". Whenever I had a short somewhere, it was either a solder bridge between two strips on the strip board or a wire touching something it wasn't supposed to touch due to the insulation shrinking/melting somewhere.
In hindsight it would have been easier to just use SMD resistors instead, but I had a bag of regular 1/4W resistors that came with the LEDs on hand.
