Author Topic: Voltage drop across resistor  (Read 1429 times)
Offline medical-nerdTopic starter
  • What's that coming over the hill?
« on: June 21, 2018, 12:50:10 pm »
Hiya
Aaaarghhh....
I'm probably having a face palm moment but am having a blank at the moment.
I know how to calculate basic voltage drops using ohm's law by calculating current flow first. But what do I do if current is a known fixed value?
If I have a module that uses e.g  275mA at a supply of 5V, if there is a resistance of 10ohm after the voltage regulator, what is the voltage drop across the resistor?
Cheers
'better to burn out than fade away'
Offline capt bullshot
Re: Voltage drop across resistor
« Reply #1 on: June 21, 2018, 12:51:25 pm »
U = I * R
multiply the current by the resistors value
Offline mikerj
« Reply #2 on: June 21, 2018, 12:59:43 pm »
At 275mA a 10 ohm resistor will drop 0.275*10=2.75volts.  The problem here is that with the resistor in circuit your load is now only seeing 5-2.75=2.25v, so is unlikely to be taking 275mA any more (unless it's a constant current sink).  Current sensing resistors usually have low values to minimise voltage drop, which may then require amplification to get a useful signal.
The following users thanked this post: medical-nerd
Offline Audioguru
« Reply #3 on: June 21, 2018, 01:17:07 pm »
Is the 10 ohms resistor in series with the 275mA module? Then the module is not getting 5V and probably is not drawing 275mA anymore.
