Ok, I'm quite a novice as some of you have probably already understood from some of my other posts.
BUT... I had a faulty Power adapter that I thought I could quite comfortably fix... how wrong was I!!
Basically I looked at the board and came to the conclusion that one of the transistors was faulty so I figured I would swap them for new ones, the problem was that the two that were there were ones I didn't have so I substituted one of them a C945 for a 2n3904, the pin out was different so I resolved that by crossing the pins over before soldering them in (no they didn't touch)
I plugged in the supply, waited for the bang and it didn't happen, the LED came on and I was overwhelmed with joy, I HAD FIXED IT
The amazement was short lived however because 10 seconds later as I was about to check the output was 7.3 volts with a multimeter all hell broke loose, the whole supply went BANG, not once but 3 times, first the cap blew off, then a transistor or two then a resistor, not a single failure but 4 separate components blew off the board!
I attach 2 pictures to show the damage and hope that someone can show me where I went catastrophically wrong.
