Author Topic: spectrum analyzer showing dBuV  (Read 2458 times)
Offline kumarTopic starter
« on: December 22, 2014, 07:37:08 am »
I have a spectrum analyzer which displays dBuV on y axis. Is it the field strength that is displayed? ( I mean, dBuV/m)
Offline IconicPCB
Re: spectrum analyzer showing dBuV
« Reply #1 on: December 22, 2014, 08:22:41 am »
NO....
Offline PE1RKI
« Reply #2 on: December 22, 2014, 08:41:29 am »
with an antenna used for emi measurements and a correction table, then yes.
« Reply #3 on: December 22, 2014, 09:02:34 am »
I forgot to mention, a near field probe is connected to the analyzer to check the emission from an equipment.
Offline PE1RKI
« Reply #4 on: December 22, 2014, 10:23:57 am »
then you should be able to load a correction or normalisation table into the spectrum analyzer or some other way to calibrate it.
Offline IconicPCB
« Reply #5 on: December 23, 2014, 03:05:11 am »
You sure?
