Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
STM32F 5V to open drain pin
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: STM32F 5V to open drain pin (Read 1604 times)
Vindhyachal.takniki
Frequent Contributor
on:
April 23, 2015, 12:59:22 pm »
1. I am using stm32f205.
2. MCU is powered by 3.3V.
3. Another ic pin is driven by 5V logic or (Vih = 0.7*VDD = 3.5V)
4. Can I set pin of STM32F2 as open drain & connect 5V by pull up to it.
5. Datasheet of MCU says that they are not true open drain pins.
Logged
mrflibble
Super Contributor
Country:
Re: STM32F 5V to open drain pin
Reply #1 on:
April 23, 2015, 01:11:30 pm »
The pins marked as 5 Volt tolerant (FT) should be able to act as an open drain connected to a 5 Volt rail. As long as you use an external pullup (as opposed to the internal weak pullup), and keep the current limited you should be fine.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
