Both of those are FET input, so that's not it. The most likely problem is that you're violating the input common mode range of the op amp. In fact, if you check the data sheets, you'll see that your violating the common mode input range of both of them, but by a lesser amount with the OPA2132, so it's probably being more forgiving.
