Author Topic: Strange voltage measurements on power supply  (Read 3111 times)
Offline PeterVTopic starter
« on: February 01, 2015, 09:01:42 am »
I tested (measured) some older power supplies from different devices (3.7V, 4.5V, 12V-1A, etc)
Half of them are giving much higher voltages... like: 19V instead of 12V, 20V instead of 16V, even 9V in stead of 3.7V...
So I tried a working power supply for a NiMh battery of 9.6V / 600mA.  The battery gave 10.3V and de power supply 25.6V...
Settings on meter : DC, 200V
Are these supplies or my meter broken?
Has it something to do with the fact that there is no working circuit?
It tried batteries:
3V gave 3.14V
9V gave 9.46V
new 1.5V gave 1.61V
home AC gave 224V (220V for Belgium)
Someone an idea?
Offline Richard Crowley
  • KJ7YLK
Re: Strange voltage measurements on power supply
« Reply #1 on: February 01, 2015, 09:09:09 am »
When you say "power supplies" I assume you mean inexpensive "wall-warts".
These are typically NOT regulated, and they very commonly have a higher output voltage when NOT loaded.
I also assume that your meter is a typical modern DMM, etc.
That means that it has a very high impedance to NOT load down what you are measuring.
So what you are measuring is the "open circuit" (unloaded) voltage of low-end power supplies.
This is completely ordinary and expected. The nominal voltage ratings are typically the LOADED design target.
« Last Edit: February 01, 2015, 09:11:56 am by Richard Crowley »
Online Zero999
  • 0999
« Reply #2 on: February 01, 2015, 09:48:41 am »
Yes unregulated wall warts always give a higher voltage when unloaded.
It's also true that batteries give a higher voltage when fresh and unloaded.
It's very important to take the above into account when selecting components, to avoid blowing things up.
« Reply #3 on: February 01, 2015, 09:57:11 am »
Yes, I didn't know.
I have plans to work with micro-electronics...
Did you hear about the "Ardumower project" yet?
http://www.ardumower.de/index.php/en/
I want to learn and to fix my broken mower...
Big challenge...
Maybe I'll need you more in the future... ;)
I added picture now.
So suggestions on materials for my "lab"?
Greetz
Offline Rick Law
« Reply #4 on: February 01, 2015, 07:22:17 pm »
Big challenge...
... suggestions on materials for my "lab"?
Greetz
You should consider one of those step-down (buck) converters to control your actual output voltage.  For the kind of app you are saying (under 1amp ish), The CV buck boards are well under $2-3, the CC/CV are well under $3-5.
The boost+buck is also a good choice.  It first boost the voltage to max (lm2577 max, 30volt-ish) then buck it back down to what you need.  So it can supply 2v-27v with any of DC wall-wart with enough power (watts).
These low cost boost/buck are not lab grade but they are more than adequate to power an arduino or something like that.
For a digital controlled buck, see this thread:
https://www.eevblog.com/forum/reviews/b3603-dcdc-buck-converter-mini-review-and-how-the-set-key-could-be-fatal/
