I am having issues with the power staying at 5V.
These are the steps that I have taken:
the timing circuit has been confirmed to be giving out 0.999 Hz. Confirmed by Hz counter on multimeter. It also gives 32.768KHz :-)
Voltage is supplied by a USB 2.5A adapter.
There is sag when all IC's are on the main board, and drops to around 4V depending on which supply I use.
I removed all IC's except for timing, Logic AND gates, and just 3 '192's.
I also then supplied the display separately, and that also drops the voltage to around 4v4
When both were powered from a single supply, it even dropped down to 3.8V
Now I have removed all the display’s except for 2, but still no joy.
What I can get, is IF I attach a short piece of Kynar wire wrap wire, to the Latch, it will jump around on the numbers but faint and as soon as I remove it, a number will show and even the dot point.
I do not have a logic probe or CRO to test, only a multimeter a Jaycar QM1535.
I have attached the Schematic and pcb files and images of the build.
I have checked for shorts, but couldn’t find any.
When there are less IC’s on the board, the power supply as counted at various IC sockets shows close to 5V, around 4.85V
Any help would be appreciated.
Are the traces the cause? That is the only thing I can think off, since I have changed over the 192’s and even left only 1 in its socket, but it still could not drive the 5082-7300. I had not had these type of problems when I was having it on a solderless bread board, but then again, I only had it attached as a counter ;-) not a whole system and had tried it with both the 5082-7300 and TIL311.
Thank you.
