Author Topic: Stumped by slow MOSFET rise time  (Read 7641 times)
Offline int2strTopic starter
« on: July 21, 2017, 05:52:18 am »
Mighty EEVBLOG,
I have the attached very simple circuit.
DIN is a 3.3V signal from an ATmega328p.
The MOSFET is a BS270
Datasheet -> http://www.mouser.com/ds/2/149/BS270-1006630.pdf
I'm using it to control WS2812 LEDs.
The problem I'm having is that despite the datasheet showing 10ms turn-on time, on my oscilloscope the nice, square 3.3V wave I'm feeding in get's turned into horrible peaks with seemingly a ~300ns rise time.
I'm saying seemingly, because the LEDs actually work. Which has me confused :D
Ideas?
Offline agehall
Re: Stumped by slow MOSFET rise time
« Reply #1 on: July 21, 2017, 06:10:50 am »
You are looking at the switching times under very specific conditions specified in the datasheet. You are feeding it a GS voltage of 3.3V and the datasheet specifies 10V, so that could be one reason why you are not seeing the expected raise time.
Offline Zero999
  • 0999
« Reply #2 on: July 21, 2017, 07:59:05 am »
Try reducing the value of R1 to 1k.
Offline danadak
« Reply #3 on: July 21, 2017, 11:07:50 am »
Spec shows turn on from a V source with 25 ohms source Z. Your Atmega output
has much higher effective Rdson than 25 ohms. Additionally you are driving the
miller C at the MOSFET gate as it moves into active region, these all contribute
to slowing down turn on & off time.  Another contributing factor is Vgs drive available,
look at the normalized gate drive vs Rdson curves.
http://www.vishay.com/docs/73217/73217.pdf
https://www.onsemi.com/pub/Collateral/AN1090-D.PDF
The resolution is to use gate drivers.
Regards, Dana.
« Last Edit: July 21, 2017, 11:11:23 am by danadak »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: July 21, 2017, 01:44:24 pm »
I don't know what to think.
Where in the datasheet does it show 10ms?
CMOS pins are typically a few ns.  It'll be a lot slower with a MOSFET gate on there loading it down.
Are you referring to the drain / output waveform instead?
Seven Transistor Labs, LLC
Offline rstofer
« Reply #5 on: July 21, 2017, 02:14:25 pm »
I had been thinking that the 10 ms number should have been 10 ns and the op is measuring 300 ns.
In any event, this particular MOSFET doesn't even pretend to be a "logic level" device.  There are "logic level MOSFETs" around that might show better switching but the fact is, a 3.3V ATmega uC simply can't drive enough gate current to get over the capacitance that is slowly charging at the gate.
Figure 5 in the datasheet shows that at 3.3V Vgs the device is barely on the curves.  Sure, it will switch a hundred milliamps but is won't do it very quickly.
That's why they invented gate drivers - a device that can dump AMPS into a gate to get it switching a lot faster.
Offline suicidaleggroll
« Reply #6 on: July 21, 2017, 02:26:11 pm »
Max Vgs(th) of 2.5v means that MOSFET is really not suitable for a 3.3v drive, you want at least ~5v drive.  Look for a FET with a max Vgs(th)<1.7, or get a gate driver.
Offline T3sl4co1l
« Reply #7 on: July 21, 2017, 04:20:18 pm »
To this end, you want low voltage MOSFETs, Vds <= 20V.  These have higher specific transconductance than conventional (>= 30V) parts, so they can be used on 3.3V, even 2.5V and 1.8V logic.
Offhand, I like RUM001L02T2CL for small switches, but the package may be inconveniently small for prototyping.
« Reply #8 on: July 21, 2017, 08:01:02 pm »
Even tried shorting R1 - no effect.
As others have pointed out, yes, NANO seconds (typo :( ).
Awww crap. As you and others pointed out, yes, 3.3V doesn't seem to be on the curve.
Sloppy part selection.
Thanks everyone!
Offline bson
« Reply #9 on: July 22, 2017, 01:14:38 am »
How many WS2812?
The datasheet for that part has no current consumption vs brightness info, so I'd start by measuring current consumption at my desired brightness.  Multiply this by the number of LEDs, and that's the drain current the MOSFET needs to handle.  A BSS806 might switch fast enough, and has Rds(on) on the order of tens of \$m\Omega\$ so can easily handle 1.5A - as long as you switch it fast enough.
By the way, if the WS2812's power on in an off state, then switching speed may not matter.
« Last Edit: July 22, 2017, 01:35:10 am by bson »
« Reply #10 on: July 22, 2017, 06:09:50 am »
The MOSFET is only for the data line, not drawing any current really.
Offline bson
« Reply #11 on: July 22, 2017, 07:57:42 am »
The WS2812 datasheet suggests the data line current consumption is 1uA, so you can probably connect that directly to the I/O pin.
Offline Beamin
  • If you think my Boobs are big you should see my ba
« Reply #12 on: July 22, 2017, 08:41:22 am »
Mighty EEVBLOG,
Ideas?
Pardon my ignorance but how does that circuit work? I could see if it had one led that fed into the mosfet but how is that LED wired and why does it have a pin going to ground and not to the source(top) of the mosfet in the scematic?
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
« Reply #13 on: July 22, 2017, 06:38:00 pm »
I/O pin is 3.3V, WS2812 needs 5V in this case.
« Reply #14 on: July 22, 2017, 06:39:43 pm »
LED is not one LED, it a strip of WS2812b LEDs:
http://www.seeedstudio.com/document/pdf/WS2812B%20Datasheet.pdf
Offline bson
« Reply #15 on: July 22, 2017, 06:56:35 pm »
It doesn't need 5V, it needs 0.7*Vdd.  If you drop the 5V with a diode you get 4.35V and VIH becomes 4.34*0.7 = 3.04V.  A Vdd of 4.35V is perfectly within its range of 3.5-5V.
Offline T3sl4co1l
« Reply #16 on: July 22, 2017, 08:02:27 pm »
74HCT07 or '17 has TTL/LVCMOS compatible inputs and 5V compatible outputs ('07: open drain).
« Reply #17 on: July 23, 2017, 11:02:53 pm »
Yes, I've seen that trick. But you have to "sacrifice" one LED and it's really no easier than using a MOSFET.
Offline David_AVD
« Reply #18 on: July 24, 2017, 12:56:19 am »
The usual way to do the voltage translation for driving pixels from a 3.3V micro is to use a 74ACT541 or similar buffer.
The buffer is run from the 5V supply, but has 3.3V compatible inputs.
« Reply #19 on: July 25, 2017, 05:20:29 am »
Wow, I'm really questioning my life choices right now....
Replaced the MOSFET with this one:
http://www.microchip.com/mymicrochip/filehandler.aspx?ddocname=en570658
Now I'm not getting any real output at all, just ground+noise. :(
So what's wrong with my part choice now? :(
Offline David_AVD
« Reply #20 on: July 25, 2017, 06:11:07 am »
More likely incorrect connections.
« Reply #21 on: July 25, 2017, 06:34:45 am »
I have made a PCB for this. So same connections as with the other MOSFET.
Also measured everything. Source is ground, Drain is 5V / output and Gate is 3.3V signal as in the original schematic.
« Reply #22 on: July 25, 2017, 07:48:37 am »
It's speed once again :(
At around 90kHz or so the signal breaks down.
Online MK14
« Reply #23 on: July 25, 2017, 08:24:37 am »
Probably because R1 10K will give a slow rise time, as it takes time to charge the stray (including the Fets contribution) capacitance.
Lower R1 to e.g. 1K or use the other suggestions in this thread, such as logic gates. Which should be considerably faster.
Offline David_AVD
« Reply #24 on: July 25, 2017, 08:40:20 am »
If you're still using that 10K pull-up that's definitely an issue.  You need to drive the pixels with a lot lower source impedance than that.  Even 470R is only around 10mA of +ve drive.
