Hi all, this is my first post to a forum, ever, so please excuse any faux-pas I make. (constructive criticism is most welcome!)
I've got an electronics technician level of training (over 10 years ago so I am a little rusty), and am a little over my head with this personal project I've taken on. I am building an automotive booster pack out of some supercapactiors I've purchased. I've attached a JPG of my circuit diagram, as well as the TinyCAD file from which the JPG was created.
First of all, sorry for the poor layout of this circuit diagram! It started out simple and clean enough but got out of hand as I discovered more and more problems that needed resolution. I'm looking for help in finding design flaws, incorrect part implementation, and any other issues you may come across before I go ahead and buy the parts to put together a working unit. Any recommended part substitutions are welcome. I would be very interested in design simplifications as well...the fewer parts the better! As long as it doesn't compromise any of the design goals. Hopefully none of the magic smoke escapes when I first apply power!
Design goals:1. Prevent overcharging (and damage) of each individual supercapacitor (balancing is not really a concern)
2. Eliminate parasitic supercapacitor loads to maintain charge as long as possible while in storage
3. Charge supercapacitors at a safe rate
4. Prevent boosted load from backfeeding supercapacitors into overcharge condition
5. Protect against booster cables hooked up backwards
Questions:1. Do I have the + and - inputs on the comparators reversed?
2. Will negative voltage from reversed booster cables fry the comparators or anything else?
3. Will connecting together the Supply and Output grounds of the up/down converter blow it up?
4. Have I correctly wired up the MOSFETs? Are the Gate resistors necessary/correct?
5. Will the main power relay flicker due to variable load voltage while starting the boosted car?
6. Does anyone know where I can get a 14V fixed linear LDO voltage regulator? I don't want to have to use an adjustable one. I don't see any on Digikey, which is where I will be purchasing the parts I don't already have.
7. Have I chosen the correct parts for my application?
Notes:1. All unlabeled diodes are standard IN4007.
2. 3400F capacitors are Maxwell BCAP3400.
3. The Up/Down converter I am considering can be found here:
http://www.ebay.ca/itm/4005974302804. The solar panel and SLA battery are removable.
5. The SLA battery will have an independant maintenance charger connected to it on occasion.
6. The relay connecting the supercapacitors to the booster cables is rated for 14V 700A. (12V coil) I already have it.
7. I will of course be using appropriately sized wiring.
8. Ignore the pinout numbers on the comparators...they're set in TinyCad and I can't see how to remove them.
9. Red LED part # LTL-4263
10. Green LED part # LTL-307G
11. Yellow LED part # LTL-307Y
12. Blue LED = 10mA, unknown voltage...I already have it, I'll figure it out and adjust the resistor accordingly.
13. VoltMeter Relay part # HE128-ND
14. All low power MOSFETs are part # FDU3N40TU
15. All high power MOSFETs are part # TK40E06N1,S1X
