Hi Everyone,
I'm building a gate controller using two SPDT relays to control an actuator. I've suppressed both relay coils with a 1N4004, which is fine. (I think). But the output for the actuator also needs suppression, correct? But the polarity reverses every time I reverse the direction of the actuator motor. What should I be doing in this application?
Also, should I be adding 1nF capacitors parallel with the coils?
Thanks!
