I'm building a plant light for home. I have built one previously using the Luxeon Rebel Color Stars - The ones that were already mounted on PCBs. It seems like the PCB versions are quite limited in availability, though. Of course it need not be necessarily Luxeon Rebel Colors as long as the chip is good and the wavelength is suitable.
What I would like to ask the people here is that how is working with the bare LED chips? They seem very small and a hassle to work with. Also with the cathode and anode mounted on the same side as the thermal path they would require some isolation/grinding in order to glue them to a piece of copper for heat dissipation.
I'm thinking about 150-200 ?mol/s*m^2 and looks like it would be 30-40 high power LEDs. What kind of powering option would people recommend for that? Previously working with 10 LEDs I just used a constant current driver - Should I just go for a 100+ Watt constant current driver for this too?
I attached the spectrum of the lamp I previously built - I am probably making a similar spectral composition but also adding some white LEDs to get at least some of the rest of the active spectrum.
