Well that board appears to be very simple. Its just switches and indicator LEDs.
Can you measure the resistance of an igniter? Caution: there is a risk of it igniting so don't use an analog meter and don't use one that uses a high test voltage. Use long enough wires that you don't have to hold the igniter, and place the igniter on a flameproof surface while testing it.
