Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
switch mode adapter with output voltage listed as a range
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: switch mode adapter with output voltage listed as a range (Read 1044 times)
rstor22
Regular Contributor
Country:
on:
May 21, 2018, 10:30:41 pm »
I found the following switch mode adapter (model 3A-061WP12) which indicates the output is 9-12V 6W it also says @12V 0.5A.
What does this range of 9-12V refer to?
https://images-na.ssl-images-amazon.com/images/I/91-sceQP4TL._SL1500_.jpg
http://p.globalsources.com/IMAGES/PDT/SPEC/098/K1009205098.pdf
Logged
Audioguru
Super Contributor
Country:
Re: switch mode adapter with output voltage listed as a range
Reply #1 on:
May 22, 2018, 12:29:46 am »
It might be a bad translation or some of them have poor voltage regulation.
Logged
rdl
Super Contributor
Country:
Reply #2 on:
May 22, 2018, 03:01:18 am »
A few years ago, I tested a 9 volt regulated switch-mode adapter from a well regarded supplier in NYC. At less than 80% of its 1 amp rated output current the voltage had dropped to nearly 7.5 volts.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
