I would like to use a switch regulator in order to regulate a voltage supply that changes from 17.5V when running off a solar panel and 7.2V when running off a battery. Is it possible to do this? The problem is that the inductor value for these circuits only covers a small range of voltages. I have used switch regulators in the past but for a fixed input voltage value not one that fluctuates over such a high range.
The current being drawn by the load after the regulator is of 0.5A and I would like to keep the circuit as efficient as possible.
