The Atmega wants to be driven with a constant V. That takes care of
device to device and I/O load variation, eg. if load changes device V
stays the same, in spec.
A constant I driver, for load changes, supplies a fixed current. LEDs
like to be driven as constant I so that led to led in a given strip put
out roughly same brightness, and are invariant to led to led manu-
facturing parameter differences.
Note your tube may incorporate internally a constant current driver.
Hence its input, a V, feeds constant current driver input. Some really
cheap strips just use a R to effect a crude constant current. But LED
device threshold, led to led, vary all over the map.
Regards, Dana.
