2.2v will work.
Take a lm317, from its output pin wire a resistor to your laser diode -> the resistor here will set the current levels when the laser diode is turned on.
From the adj pin, wire a small resistor (110ohm for example - determined by the maximum current you want the mcu's pin to sink) to the laser diode as well.
Connect the mcu's control pin to the adj pin directly.
Initialize the mcu's pin to output a low.
To turn on the laser diode, turn that pin to input; to turn off the laser diode, turn that pin to output.
Done.
