Author Topic: Tape Measure With Shorter Inches?  (Read 6412 times)
Offline robobeamerTopic starter
« on: February 25, 2016, 04:53:49 am »
Has anyone ever seen a tape measure with shorter inches?  I remember Dave talking about is some time ago.
Offline IanB
Re: Tape Measure With Shorter Inches?
« Reply #1 on: February 25, 2016, 04:56:19 am »
They are called centimeters  ;)
Offline Addicted2AnalogTek
« Reply #2 on: February 25, 2016, 04:59:41 am »
I don't know about shorter inches, but there is an "engineer's rule" - each foot is split up into 10 segments instead of 12.
You've got me curious now, though.
Offline jobog
« Reply #3 on: February 25, 2016, 05:30:57 am »
Pattern makers have rulers that compensate for the shrinkage of various metals.  A rule for steel castings would indicate 1" but would be longer than 1" to adjust the pattern for shrink.
Offline RogerRowland
    • Personal web site
« Reply #4 on: February 25, 2016, 05:44:23 am »
Maybe something like this?
http://fishfib.com/
Offline mtdoc
« Reply #5 on: February 25, 2016, 07:40:23 am »
You might look in the advertisements found in the back of "mens magazines"....
Offline G7PSK
  • It is hot until proved not.
« Reply #6 on: February 25, 2016, 09:44:17 am »
I have seen a tape measure printed on elastic so that you could stretch it to fit.
Offline mzzj
« Reply #7 on: February 25, 2016, 09:54:55 am »
U.S. surveyor’s inch would be slightly longer by 2ppm :-/O
All REAL americans should use  surveyor’s inch instead of sosialistic-communist based modern inch  :-DD
Offline Rerouter
« Reply #8 on: February 25, 2016, 10:03:29 am »
hmm, so my board would have to be 500 inches long before i was effected by 1 thou difference, somehow i fail to see apart from things like 100's of miles in distance why the 2 standards?
I mean you already have Australians using thou, and now you want us using US surveyor's thou, stuff it, i'm going back to decimeters
Offline DenzilPenberthy
« Reply #9 on: February 25, 2016, 10:18:43 am »
I remember reading a while ago about a batch of Chinese knock-off tape measures where either the feet were sub divided into 10 'inches' or the 'feet' were only 10 real inches long, I can't remember which way round it was.
Offline mzzj
« Reply #10 on: February 25, 2016, 10:33:09 am »
Thou shall not pass  ;)
Offline tszaboo
« Reply #11 on: February 25, 2016, 11:54:31 am »
Do you want to prove something to your GF?  :-DD
(sorry. could not resist.)
Offline TimFox
« Reply #12 on: February 25, 2016, 02:30:20 pm »
Yes, when the US finally went really metric in 1959 (without telling anyone), they changed the definition of the inch to exactly 2.54 cm, instead of the old definition of the meter as 39.37 inches, resulting in the "US Survey Foot" that followed the old definition.  Otherwise, we would have had to change every single land-tenure document (deed) in the entire country, which didn't seem worth the trouble.
Offline zapta
« Last Edit: February 25, 2016, 03:00:36 pm by zapta »
