Author Topic: TDA2822 Bridge Amplifier  (Read 6163 times)
Offline MasonMSTYTopic starter
« on: January 23, 2016, 08:45:10 pm »
i am planning on building a amp based on the TDA2822M chip. I am new to electronics and trying to lean to read schematics and thought that this would be a good project to start on. the only problem i am having is there is no speaker in the schematic so i do not know where to hook my speaker up at.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: TDA2822 Bridge Amplifier
« Reply #1 on: January 23, 2016, 08:55:22 pm »
The speaker is represented by RL
« Reply #2 on: January 23, 2016, 08:59:50 pm »
Okay Thanks. Thats what i was thinking but i just wanted to make sure before i started making it.
Offline Audioguru
« Reply #3 on: January 23, 2016, 11:40:39 pm »
The TDA2822M is obsolete and is not made anymore. The two largest electronic parts distributors in USA do not have any. It was small and it overheated easily.
The LM386 amplifier IC is still made and is available everywhere.
Online Zero999
  • 0999
« Reply #4 on: January 24, 2016, 09:30:10 am »
The LM386 is not a replacement for the TDA2822.
The NJM2073 seems pretty decent though.
http://www.njr.com/semicon/PDF/NJM2073_E.pdf
Offline stoica adrian
« Reply #5 on: January 24, 2016, 10:45:42 am »
Hello,
In my opinion if you are a beginner in electronics, you should try to make an amplifier with transistors, you have a lot to learn from there. I suggest you this headphone amplifier
http://www.circuitstoday.com/few-transistor-amplifier-circuits#headphone
Enjoy
Offline mikerj
« Reply #6 on: January 24, 2016, 01:29:21 pm »
Just FYI, production of the genuine LM386 is being stopped later this year.
Online wraper
  • Country: lv
« Reply #7 on: January 24, 2016, 01:50:04 pm »
Hello,
Enjoy
TBH building low power transistor amp is nearly useless if going to actually use it, something with at least a few tens of watts is another story. By the way, all of the circuits from your link suck (if you are going to actually listen them).
Offline picandmix
« Reply #8 on: January 24, 2016, 05:35:01 pm »
Then I would suggest you get one of these LM386 amplifier kits widely sold on ebay, and you might find someone stocking  them in your country; cheaper than buying the parts separately and includes a pcb  and volume control.
If you can to improve things with a pre amp then plenty of good circuits here.
http://sound.westhost.com/project02.htm
Online Zero999
  • 0999
« Reply #9 on: January 24, 2016, 06:32:56 pm »
There are clones around. Try the NJM386.
http://www.njr.com/semicon/PDF/NJM386_E.pdf
By the way, I'm no New Japan Radio shill but I've got some of their copy of the NE5532 and they've quite good and were cheaper from RS Components.
Offline Audioguru
« Reply #10 on: January 24, 2016, 06:36:50 pm »
It looks like American companies are not making though-hole DIL ICs anymore. also, now that TI bought National then the foundry that made LMxxx parts might also be gone.
Online Zero999
  • 0999
« Reply #11 on: January 24, 2016, 07:23:13 pm »
Hello,
Enjoy
It depends on what you want to learn? If it's just a bit of soldering practise, an LM386 amplifier is perfect.
As mentioned above those circuits on that website aren't very good.
« Reply #12 on: January 24, 2016, 08:47:24 pm »
Well, if you just solder some components on a pcb using a schematics, and at final everything works thats great. But what you have learn? to solder yes, to recognize a schematics and components yes, but for me it's more like making a kit. You have more to learn when you make things that do not work, and then you scratch your had to work. But at the end depends what satisfy you
