Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
TDA7492 Power
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: TDA7492 Power (Read 1020 times)
modernjack3
Contributor
Country:
TDA7492 Power
on:
July 06, 2016, 05:39:07 pm »
So ist me , the car battery guy again and I am having a big Problem - I just figured out tht my battery guard isnt really made for Music use since this Is a Wave and no constant current - and I just wondered if I could do it by time instead - Can I use the datasheet of the TDA7492 and the 8 Ohm load curve ?I want to get my supply voltage for this board :
https://www.amazon.com/KKmoon-Wireless-Bluetooth-2-channel-Amplifier/dp/B01BV8LM5Q
down to 13 V so it can Output a MAX of ~15 W per channel ( says the datasheet) is my thought correct ? Does the datasheet even fit to my board or is there a step up conv built in ?
so many questions ...
Datasheet :
http://www.st.com/content/ccc/resource/technical/document/datasheet/f4/3e/da/a3/97/e7/4f/8d/CD00205863.pdf/files/CD00205863.pdf/jcr:content/translations/en.CD00205863.pdf
8 Ohm caracteristics..
Greetings Jack !
PS : My battery says "650W if discharged over 20 Hrs" so id like it to drain about 32W
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
TDA7492 Power
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
