There is no "scaremongering" here, just cautions that Teflon is inert until heated to high temperatures --- at which point it gives off very toxic decomposition products.
It is scaremongering when it leads to people gaining the impression that they need to be careful merely handling PTFE as at least one commenter has said.
It is pretty much common sense that combustion or heat decomposition products of
anything are likely to be harmful, PTFE is neither unique nor particularly especially harmful in that context. Like I said, the risks of soldering PVC coated wire (lower melting point, lower decomposition temperature, equally nasty decomposition products) are probably higher than soldering PTFE coated wire, and I bet a goodly number of folks here solder PVC coated wire on a daily basis without a second thought.
