Similar fault to the one discussed in the forum before
https://www.eevblog.com/forum/beginners/textronix-475-needs-repair/msg182079/#msg182079In my case there was power to some things like the graticule illumination and other bits but no screen. I pulled the cover off the HV components and the neons were not lit. Then I did the obvious and poked around the supply lines and found the -8V line is at +800mV. Not surprisingly the -15V line is at -23V (given the ground line for U1464 is the -8v line this makes sense).
The question is where to start.
Someone already replaced the filter cap on the 5v line (it's blue and there is a wire bridged over to the earth on the component side for the third leg).
The big transistor Q1468 looks Ok when I poke it with the DMM in diode mode.
I can't easily poke the bridge rectifier as I need to get down deep into the unit.
The voltage at the collector of Q1468 is about 660mV when the unit is on. On my other scope it looks like a high frequency sine wave with around 800mV P-P
So is it the bridge or the cap? How do I tell?
