I recently bought a Tektronix 2215 off of eBay. The seller said that he did not test every function, but he did connect the probe to each channel and applied a sine wave. On the pictures the trace touched both sides of the screen. When I tried out the oscilloscope, the trace does not touch both edges of the screen. It goes from the middle of division 4 through division 8. I've tried fiddling with all the knobs and switches, but nothing helps. I downloaded the operator's manual and service manual from Tektronix, and went through the steps to get the initial baseline. Unfortunately, I cannot fully calibrate the scope right now because I don't have a signal generator.
The serial number on the scope match the serial numbers of the scope in the eBay pictures, so I know it's the same scope. That leaves two possibilities: 1) there's some knob or switch I haven't found yet that will fix the problem, or 2) something broke between the time he took the pictures and the time the scope got to my house. Either way, has anyone seen this problem before and know what to do about it?
Thank you very much for your help!
Dan
