Thanks to all for you reply, as I said, I'm an electronics beginner, most a DIY and I don't know how to use an oscilloscope very well yet, I haven't put any input signal yet because I don't have the test probes, I can find it on ebay to see if it's work.
If you simply (carefully) insert a small wire into the center of the BNC connector for one of the channels, it will likely pick up enough stray 50/60Hz from the air to show that the vertical deflection works.
https://www.youtube.com/watch?v=vFqxn6VGYC0https://www.youtube.com/watch?v=VJJ-y9gjjkIhttps://www.youtube.com/watch?v=uOAzRlhrnYEhttps://www.youtube.com/watch?v=VWodjUSkYVEhttps://www.youtube.com/watch?v=juWby10TheQhttps://www.youtube.com/watch?v=0dmxjXDa_vAhttps://www.youtube.com/watch?v=lquVxxVNHgUhttps://www.youtube.com/watch?v=CK3R08RMDx0https://www.youtube.com/watch?v=zrDxSM91Jcg
