Hi, i have this CD player for years and one day it didn't turn on, so i went to investigate and find a burnt resistor.
I swapped it with a 1k resistor and the LCD was dim, i swapped the 1k with a .680k one and it was the same dim lcd and no power to the laser head motor.
This is a long shot, anyone had the same problem?
It looks like it is not getting enough current going in.
Buttons work, LCD back light works but a little dim, front equalizer LED's look normal.
No movement of the laser head or its lens focusing system or laser light.
I even tried with an external power supply with 3,000 volts on the multimeter and no difference.
thanks.
