I have a couple of cheap Chinese stand alone temperature measuring devices using K types, a K type on my uni-t 60 DMM and I've just bought a 3 wire PT100 which I've wired up as four wires and connected to my Keighley 6100.....
The PT100 reads 21 at room temp & 35 against skin (both about right) but 190 against my soldering iron tip which is supposed to be at 290.
The two Chinese stand alone are about 5% out from each other.
They all read different values. How do people check them? How can you calibrate them?
I could try for 100 degrees using the kettle but not many other repeatable temps.
