Are the frequency response measurements performed with steady state sine waves?
Log sine sweep. Also, I am only driving the dummy load to 1 watt. The amp is rated for peaks of 14K watts so I can't imagine it would be clipping without melting my 20 watt power resistor.
Can you slow the sweep speed down or up and check for frequency response differences?
If the measurement problem is due to switching noise can you add a low pass filter (something like 1 kohm and 10 nF) at the output of the voltage divider and compare the frequency response of the Crown with the Lab gruppen?
The lab gruppen fp series is sold as an amplifier to go touring so some compromises may have been made.
I don't like their web site, it uses BS:-
Regulated Switch Mode Power Supply (R.SMPS™), pointless acronym, nearly all smps have regulated outputs. Nearly all switch mode power supplies use ferrite core transformers. Where is the innovation?
Class TD. Difficult to get a Class D stage supplying a Class A/B stage and is likely to still have switching noise on the output.
Multiple Position Gain Switch (M.PGS), it's got a gain control, wow.
