Well, the physical layer will always be the first step. "Is it plugged in, and not destroyed, physically?" Then, link layer (Thou shall always check voltages). Beyond that it falls apart, yes.
There probably is a less precise layer model that could be applied, but with analog stuff it'll get so fuzzy that the layer definition would change wildly from circuit to circuit. For digital stuff, the OSI layer (or an analog of it) would apply a bit more.
Anyway, for me, and I'm new at this, it's physical, voltages, then go from there. If the thing isn't destroyed, it is plugged in, and the voltages are all good, and the thing still isn't operating, it's because I missed something somewhere. Shorts and open circuits show up in voltage readings, if you have the know-how to know what you should be seeing.
