Just getting into electronics soldering. There seems to be a lot of varying opinions on what flux, when to use or if to use, etc. Some fluxes are said to produce corrosion. Some say clean it up with Iso Achohol, others don't mention cleaning at all.
**My immediate purposes will be for minor repairs to laptop charging jacks and such.
Other than that, I'll be practicing on old circuit boards from old, broken or unwanted devices and can see myself diving in as I learn more.
I am starting off with the Hakko FX888D-23BY, which came with various tips, conical to chisel.
I just bought a 1lb spool of Kester 44 RC 63/37 .031.
I also wonder about the voracity of those who claim that merely mixing rosin with Iso (and a bit of glycerine for stability) is the best solution (i.e., good adhesion, low fumes...).
I do have experience with other forms of 'hot joins' in the form of arc welding (Lincoln Welder), brazing, silver soldering using acytelyn & oxygen, MAP gas, etc.
Any other beginner's advice also appreciated. For instance, type of work surface, tip cleaning compound (mix of flux and??) etc.
Thanks!
