I use a lab power supply that tells you how much current your circuit is using in mA. It's pretty obvious that if your circuit that contains a low power microcontroller and a few other chips and should consume maybe 20mA is consuming 100mA, and that figure is rising, there is something seriously wrong, like what you are talking about. That is what you will see, current way too high and rising, a rather obvious telltale sign. Get a supply like that. It's reassuring to be able to look at it any time you want to see how much current the board is eating.
