hi folks, so i have been mucking around components/PCB thermal thingies ...
say this situation :
junction --> plastic case --> ambient
if ambient is 30oC
if R-ja = 50oC/w
and the plastic case measures in at 50oC
to get to actual T-junction, we find the watts going thru the plastic case( = 20/50 = 0.4watts)
and the junction temp is = (0.4 x Rja) + Tcase ? = 70oC
am i right? i have the feeling that i am missing something ...
does R-ja actually means the resistance going thru the plastic package? or the entire item ?
You don't really have enough information to say anything here.
Rja is from junction to ambient (from junction to surrounding air). It says nothing about the case temperature, so any measurement of the case temperature must be thrown away. Now you are left with the air temperature alone. With only the air temperature you can say nothing at all about the junction temperature. It remains a complete unknown.
On the other hand, suppose you also know the power dissipated by the silicon (= voltage drop x current), then you have two pieces of information, and now you can do a calculation. You have:
Power = (Junction temperature - Ambient temperature) / Rja
Therefore:
Junction temperature = (Power x Rja) + Ambient temperature
Any time you have one equation in four unknowns you need to specify three of the unknowns in order to calculate the fourth.
