Author Topic: Thermal Calculations  (Read 2784 times)
Offline ElectricGuyTopic starter
  • Country: pt
« on: October 12, 2014, 01:28:29 am »
Hi all;
I'm trying to calculate a thermal caracterisic of a regulator.
Since i will not use dissipator, the formula is;
Tj = Ta + (Rja x PD )
or
Tj = Ta + (Rja x PD ) + (Rjc x PD ) ???
I look at  google, but i allready see the 2 formulas, so i don't know each on should i use.
Thank you!
Regards
ElectricGuy
Offline bobcat
Re: Thermal Calculations
« Reply #1 on: October 12, 2014, 11:05:27 am »
The first formula is for a free standing device like a TO-220 without a heatsink.
The second formula is for a device that in addition to dissipation into free air, it also uses another heatsink, such as a pc board.
Offline kxenos
  • Country: gr
« Reply #2 on: October 12, 2014, 11:43:33 am »
I think the second formula is wrong.
You either leave the device free standing in which case you need the R(junction-ambient) or you're fixing the device on a heatsink in which case you need the R(junction-case), the R(case-heatsink) and the R(heatsink-ambient).
Offline KerryW
« Reply #3 on: October 12, 2014, 12:28:35 pm »
You are right, kxenos, the 2nd formula IS wrong.
Rja = Rjc + Rcs + Rsa
The spec sheet should give values for Rjc and Rja.  The Rja value assumes no added heat sink, so the case IS the heat sink, and Rja = Rjc + Rca
jc - junction to case
ja - junction to ambient
ca - case to ambient
cs - case to sink
sa - sink to ambient
So for a TO220 regulator that specifies 3 d/w Rjc and 75 d/w Rja, without a heat sink, 1 Watt would generate a 75 degree rise above ambient.  With a 5.5 d/w heat sink, you would have
3 d/w Rjc
.5 d/w Rcs (approximately)
5.5 d/w Rca
9 d/w Rja, for a 9 degree rise at 1 Watt.
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
  • Country: pt
« Reply #4 on: October 12, 2014, 11:47:41 pm »
Thank you all;
Like i said before, i will not use heatsink, so Tj = Ta + (Rja x PD ).
Thank you once again!
Thank you!
Regards
ElectricGuy
