Start breaking things down into smaller sections (mentally) and test those. Follow where the wires go, draw a schematic on paper if that helps. Try checking continuity between each plug prong and whatever the other end of the wire connects to, check across the switch with it both off and on, you should see OL with it off and 0.0 with it on. Somewhere along the line you'll zero in on the open circuit. It's like locating a kink in a garden hose, you look at one part of the hose and see that it's plump so the kink must be downstream. You walk around the corner and find limp hose, so you start moving inward from each end until you find the spot where it changes from plump to limp and that's the clog or kink.
