The TW-1 arrived. Used but seems to work. It arrived with a notch blade for larger wires to I just ordered a straight one for thinner wires. This will also get me clean screws and better contact.
This this is massive, built like a tank and weigh 15 oz. Nor surprise they last forever. It has a transformer inside and two separate outputs for each of the blades. Very high current and low voltage, about 1VAC with open blade.
It melts the teflon easily and for the first time, I am certain that I did not nick the conductors. With teflon wires, even a small nick causes the wire to break, not sure why, maybe because of the stiffness of the insulation.
