I suspect I already know the answer to this, but if I don't ask I'll never be sure. I'm a beginner, only rudimentary soldering skills. I've got an old Acer Aspire laptop, a little while ago it developed a flickering screen fault and after a little googling we determined it was the backlight, and I put it to one side. The laptop works fine on an external monitor, and the backlight would sometimes appear to be fine for a few minutes until the machine warmed up, sometimes altering the angle between screen and keyboard would cause it to show fine (or go completely black) etc. You can get replacement lcd cables on eBay for a few quid, if it were just the lcd cable I'd have replaced it in a heartbeat.
I opened it up tonight just as a change of project, and after a little gentle exploration (and some googling) I confirmed it was a torn/degenerated backlight ribbon cable within part of the overall LCD display - there's a ribbon that runs from inside the panel, along the outside to a connector that is still on the panel (rather than in the laptop). Putting very gentle pressure with a plastic spudger would cause the display to light up (or go black) etc etc. It looked like the kind of ribbon cable where you just push it into a connector so I gently tried to undo it with a view to trying to reseat it - and predictably it fell apart. :-)
I just want to confirm that this isn't something I can fix by soldering some ribbon cable onto the bit left on the panel. I mean, the iron would probably melt the ribbon anyway, even if I could source some more ribbon, and I guess that introducing even very thin gauge wiring would be almost impossible to do...?
But if there's a slim chance that someone might say, 'oh, you can do this (insert clever trick here) and it might work' then I'll give it a go - I gave the laptop up as a lost cause, it owes me nothing and it really doesn't warrant the £70 or so for a replacement lcd panel, but if it can be repaired then it's something my young daughter can play with until it breaks for good.
(I felt this belonged here rather in the repair forum as my lack of advanced skills is probably more of a factor than any clever repair know-how).
Any thoughts?
The attachments here show the cable, how it was originally bent over itself to make a 90 degree turn, and where it goes into the socket. Also you can see where the other end of it bends off into the innards of the panel.
Thanks in advance (fan of the youtube channel, first time post here, sorry if this is deemed stupid or inappropriate).
