I got all the holes milled to depth and may make an aluminum ring to press around the circumference to hold the magnets, or I may just super glue them.
I have a good idea for the body now too, since the RT is set up...
A question or two:
I was thinking of using 4 transistors to swap voltage polarity across the windings (12 transistors total). I was going to wire them as Wye, but without the return lines connected together as neutral. The return lines would feed through transistors to ground. I would have pulsed AC square wave, each phase 120° degrees apart. This seems like it would work, but not sure. I attached one phase driver for reference where V2, V3 are out of square wave from mcu. I used an inductor for the winding with 0.1L and 2Ω series resistance. LTspice shows ~1.2A through the coil.
If that would work, I have not yet seen how the motor could be wound Delta using the above driver. I'd need 6 connection points so separating each leg looks the same as above.
I also have a regular RC speed controller with three wires. How would I convert my driver so it only has three connection points instead of 6?
