Hi all, I have a very simple circuit here from the Make Electronics book. Basically it's the introduction to transistors. I understand that applying a small voltage to base is allowing the current to flow from the collector o the emitter, but why the two very different voltage drops? If I take a voltage drop between the collector, and the emitter I would think it would be somewhat close to taking the reading from the collector to the negative end of the LED, but it's not even close. The first reading is like .65mV, and the second is like 9.98V.I would think they should very close to the 9.98. Why is it not close seeing how the voltage is flowing between the collector, and emitter either way right?
