I agree with eKretz. In general, I match the tip to the work by selecting the largest possible tip that won't cause problem.
If some of your holes are connected to the ground plane, directly, or with insufficient relief, this can cause a huge problem that a skinny 1mm bevel or the like can't even touch (sans presence of a board pre-heater). Huge tip, high heat, clean tip, then hit it fast.
