Hello everyone,
So
yesterday my TIG Welder decided to stop working.
The welder only welds for 2-3 seconds and the it just stops welding. The overheating light just comes on. But I am pretty sure it ain't overheating.
So I opened the welder and I think I found the temperature sensor.
I've tried the following:
- Disconnecting the possible sensor makes the same result, which either means I am totally wrong or the sensor is totally dead and the circuit has a failsafe when no connectivity at is given
- Shorting the pins together makes the overheating light immediately come on. (Without start welding) which kinda enforces I am on the right track
- The pin has 24v when machine is connected
- I could not read any resistance values from the possible temperature sensor.
I think what I will try next is buying a 10k, 1k and 100 ohms resistance and connected them to the pin and check if I see any change in the behaviour.
Any ideas are welcome! I really need this machine to work.
