My bench is almost up and running, lacking only banana cable. Now is the big dilemma : Buy them or build them.
Already did some search in the past week, and the only one I found affordable while having a certain degree of quality is the pomona cable, around 7-8$ CAD each on digikey. I am open to more suggestion for buying them, as long as its not Chinese crap coming from ebay. I prefer to avoid spinning the wheel of luck(or wheel of quality) on ebay as much as possible, I want to buy my cable once, not buy them one time, regret my purchase, and buy another set.
If I build them, same as before, avoiding crap and want to go as much as high quality as possible, but at the same time, without costing much higher than for example, those pomona cable. Cost of cable = 2X banana connector + some cable. If the banana connector cost 10$ by itself, it will cost way more than those pomona cable...
Which banana plug would you recommend?
Which cable would you recommend?
Is speaker cable a good choice (is it cheaper than banana cable wire will offering similar or higher performance?)
I brought up speaker cable idea because I saw amazon basic cable at such low price (15$ for 100 feet) and I was wondering if it would be any good. Although, the amazon basic cable is not a good candidate because we don't have full spec.
