Hi everyone
I'm attempting to design a compensator for the feedback loop of a converter using the TL431. However there are a few aspects I'm having trouble with.
Firstly, I used the formulas in
this document to find values for R1 and R2. However their example uses I
FB equal to 0.2mA, but I have seen other examples where it's in the order of 2mA. I know there is a minimum value of I
REF but I don't understand what the method is for an appropriate I
FB value?
The other values I have based on the example of the Type 1 compensator from
ON Semiconductor. Which leads me to my other question of the correct calculation of C2. My knowledge of control theory is dubious at best but now is probably a good opportunity for me to improve that.
In their example they use C2 = CTR/(2*pi*G
fc*f
c*R
LED)
Now, I don't really know what the G
fc and f
c represent or the correct way to calculate them. Come to think of it, I don't really understand the purpose of C2 in general.
Also, I hoping to build this circuit very soon in order to understand it better. Which means ordering components asap and I'm overwhelmed by the choices of optocouplers available. What sets the optocoupler used in this application apart? Or is there even a standard model that's used?
This post turned out longer than I intended, thanks if you read it through.
edit: attached schematic, I new I was forgetting something important
