I'was born in 1992, and I've never lived in the age where metal cans are commonly used to house transistors.
That being said, I am interested to know how a TO package is capped.
I tried to search, but I didn't find much information.
To my understanding, the GTMS is only used on pin feedthrough, but not cap sealing.
Soldering is an apparent option, but is there a way that I can get around with that? My design houses an MCM in a TO can, not just a single chip, and the MCM is soldered with SAC305, so I will risk reflowing the internal if I globally solder the cap.
Laser soldering or welding is out my reach, so let's put that aside.
Is there a low temperature GTMS process that is below 217C, or is there some other ways to seal the cap?
Stud welding or epoxy sealing are appealing, but I need hermetic seals.
Another way I can think of is to use Nanofoil, but to cut that thing to a continuous ring shape without a Q switched laser is a challenge.
