Author Topic: Tool for cutting project front panels  (Read 14285 times)
Offline Dave Turner
Re: Tool for cutting project front panels
« Reply #25 on: October 08, 2013, 01:16:09 pm »
Take a look at "Q-Max cutters"  on Google.
Offline rastro
« Reply #26 on: October 08, 2013, 04:58:31 pm »
A set of fender punches can be a life-saver as well.
Can you elaborate?
Coping saw? Or the one that uses an abrasive string rather than metal blade?
Giving me ideas though for a Delta scroll saw I have (great at cutting PCB material, but makes a dusty mess).
Sorry, (copping) the spell checker got the better of me.  I was comparing a jewelers saw to a coping saw - both with tooth blades.
Offline nanofrog
« Reply #27 on: October 08, 2013, 05:39:46 pm »
Something like this: http://www.amazon.com/Steel-Punch-Puching-Tool-Aviation/dp/B001CBRK86
Thanks guys.  :)
Offline kanurys
« Reply #28 on: October 08, 2013, 11:15:14 pm »
I just remembered another good tool for making round holes in a thin sheet metal panel.  A step drill.  Great for cutting holes for things like BNCs and such.  Just keep going till you get to the side you want.  Works best on a drill press.
This is also my preferred tool. Even a Harbor Freight version is pretty handy and cheap. Yes, cheap, but this isn't as cheap as most of their stuff. You just have to make sure to brace the back side somehow so the metal doesn't deform from pushing on it with the bit.
Offline Psi
« Reply #29 on: October 09, 2013, 12:14:57 am »
A nibbler really is the best thing for cutting holes with flat edges.
It's the kind of thing you don't realize how awesome it is until you own/use one.
Offline Smokey
  • Not An Expert
« Reply #30 on: October 09, 2013, 06:48:32 pm »
A nibbler really is the best thing......
I agree... All Hail Lord Nibbler!!!!
Offline rastro
« Reply #31 on: October 09, 2013, 10:46:48 pm »
Smokey,
That is so funny see "nibblers" picture here.  I just got done google shopping for a nibbler and he kept getting in the way.
Anyway,
Looks like Radio Shack carries one for $11 but they're currently out of stock.
Offline aaronsnoswellTopic starter
« Reply #32 on: October 10, 2013, 05:23:45 pm »
Thanks all for the amazing suggestions! I'll try and pick up a nibbler and fine hacksaw on eBay.
To the person who suggested circular switches - brilliant :P
Offline david77
« Reply #33 on: October 12, 2013, 11:28:24 pm »
That was not a joke, it's just pragmatism. I avoid rectangular cut-outs when ever I can, they're tedious and time consuming. You can drill 20 holes in the time it takes to nibble/saw/file a rectangular hole.
Offline timbarnes
« Reply #34 on: October 13, 2013, 12:20:44 am »
I just finished a project where the front and rear panels are in 1/8" aluminum. My nibbler won't go quite that thick. I used a step drill for the holes, filing to clean things up (or drilling from both sides).
For the big rectangular hole I needed for my display, I used a hole at each corner, and then a jigsaw with a metal cutting blade. It's fast and pretty clean.  There's always some filing required as well.
tim
Offline Zsola
  • Country: hu
« Reply #36 on: October 13, 2013, 09:48:05 am »
Check this: http://youtu.be/ALiqAXiTQBg ;)
Offline vk3yedotcom
    • vk3ye dot com (radio articles and projects)
« Reply #37 on: October 13, 2013, 09:50:31 am »
If your drill bits don't go big enough a tapered reamer can help for larger holes.
Then finish off with a nibbling tool and small file.
NEW! Ham Radio Get Started: Your success in amateur radio. One of 8 ebooks available on amateur radio topics. Details at  https://books.vk3ye.com
Offline G7PSK
  • It is hot until proved not.
« Reply #38 on: October 13, 2013, 12:42:30 pm »
This how the geometry  of square drilling works works.
But if you are really serious about holes in metal cases you have to have one of these.
« Last Edit: October 13, 2013, 12:53:53 pm by G7PSK »
Offline geraldjhg
  • Country: ar
« Reply #39 on: October 14, 2013, 06:33:25 pm »
yeah
use round switches
square ones are a pain
G E R A L D
