I find that I only use the analog scope when I need the bandwidth (or special plugins). The Rigol for example is so much more convenient with the measurements shown on the display, screenshots, delayed timebase etc. Toss it in a bag when you visit a friend to hack up some stuff.
I don't think that the drawbacks mentioned, DSO noise and UI difficulties (the main knobs are the same as on the analog no?), are important enough for a beginner to choose an analog scope over a DSO. A very strong point for used analog scopes seems to be the price and the bandwidth. I also believe that all of us who have both an analog and a DSO and have used scopes for a long time are really biased. You don't need an analog scope as your first scope nowadays, you can do all those beginner mistakes (and more) with a DSO as well. Overall, I think that a DSO will be more useful to a beginner in the long run.
With $400.00 I would probably try to get a Tek 2465B over a new rigol, since it has 4 channels and more bandwidth. Or a Tek 465B if money was tight. If 400 MHz DSO's were a bit cheaper I would never look back. For a beginner, not sure if it matters if it's analog or not, it's an exploration tool at that stage.
