Hi, all, first time poster here.
I'm working on designing an independent dual output lab power supply - 2 floating channels with 0-20V per channel/0-1A per channel based on Dave's PSU design, with I2C control through opto-isolators to an MCU to ensure no connection between the two channels (unless I tie them together myself). It will be fully linear so I need a decent transformer to run it. So I went to DigiKey and looked for a mains transformer with dual 18-20V secondaries and found the Triad Magnetics VPP36-1560 (
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=230900071&uq=636350446503474458) which seems like it would meet the requirements. But when I looked at the datasheet (
http://catalog.triadmagnetics.com/Asset/VPP36-1560.pdf) I saw the following warning:
"Primary and secondary windings are designed to be connected in series or parallel. Winding are not intended to be used independently."
Upon looking at other power transformers, I see similar warnings for many of them.
My question is - how much of an issue is this? Can I assume that if a transformer does not have this warning it's OK to use for my purpose? Should I just go for either a -20/0/+20 non-isolated power supply, or use two independent transformers?
Of course, I could just go buy a DP832, but what's the fun in that?
Thanks!
