Thank you for the information, the problem with the transformer, was there was no power comming out it. So maybe the thermal fuse had blown.
But the pins connecting the transformer input and output pulled out when I desoldered the transformer.
Do you think that the PCB solder pins are push in?
I will investigate this, just in case the Full Compass can not supply a replacement.
One question concerning Transformer markings, is there any information to decode what the codes actually mean.
