Hi:
I picked up a relatively high voltage transformer at a Hamfest recently. It is a sealed unit, gray painted steel housing, leading me to think it is military spec.
There are some abbreviations shown on the transformer schematic that are not clear to me. Please see the attachment of the schematic.
What does "PWV" designate?
Normally, I would guess "peak working voltage", but that does not make sense to me at this time, especially when you look at the primary where the higher "PWV" of 535 does not seem to relate to the maximum 125 RMS input voltage.
But the secondaries have "PWV's" lower than the RMS values. Apparently, the transformer was meant to be used in full-wave, center-tapped rectifying circuits as DC currents are given for each secondary.
Any insight would be appreciated.
Thanks,
Ron Reeland
